If I create a 3*3 table can I configure a different query for each cell of the table?
yes you can with business text plugin
You can also look at Business Table panel:
I have to make a table like this where all the values are obtained by running different queries, google cloud computing is the data source, please can someone elaborate as in how to implement this.
@pranavgarg For the Business Table check out the latest video:
Each column can come from different datasources and you can transform column using merge from different data sources vertically.
