Can the description field of Annotation box be empty?
Can I only saving the annotation with tags only? Since I only need the tag name .
Or How can I set a prefix value to the description box if ok?
Is it suitable to use method like custom variable ? or mapping ?
Will the type of datasource and other things affect the result?
Thank you,
