can someone provide an example of call
(calling a function) in alert template,
it appears in the docs but no example is given.
call
Returns the result of calling the first argument, which must be a function, with the remaining arguments as parameters. Thus “call .X.Y 1 2” is, in Go notation, dot.X.Y(1, 2) where Y is a func-valued field, map entry, or the like. The first argument must be the result of an evaluation that yields a value of function type (as distinct from a predefined function such as print). The function must return either one or two result values, the second of which is of type error. If the arguments don’t match the function or the returned error value is non-nil, execution stops.
