Can I see same field data in different equipments on one dashboard?
I want to see same field data in different equipments on one dashboard.
For example, When I want to check equipment A’s RPM data, I select equipment A on the dashboard showing RPM, so I could check equipment A’s RPA data. And then, I want to check equipment B’s RPM data on the same RPM dashboard.
Right now, when I want to see equipment A’s and B’s RPM data, I have to make two different dashboards. This is very inefficient way. So, I want to ask is there any way to solve this problem.
Is there any way can make this using combo-box or something?
If it is possible, please let me know.
Thank you.
