Can I intersect queries?
    v9.4.7 on windows
    I want to combine 3 queries into a single table but only if a row exists in all 3 queries
    I’m not sure which transform to use
  • What happened?
    I have 3 separate panels with some repeating information, and some distinct information each
    , I would like 1 panel with only the rows that exist in all 3 queries
    it’s the same raw sql query in all 3 panels from 3 different sql server instances
    no
    I googled around for doing a set “intersect” between queries but didn’t find anything.
