Can I group heartbeat alerts for multiple customers
I’m using Loki to send a logs from the same app, but running in a different VM for every customer ({app="my-app", customer="customer-1"}), can I create a single heartbeat grafana alert that trigger if a customer log stops been sent? I didn’t want to create an alert per customer.
In theory, you could count the number of logs from given consumer in time (e.g. range query 10 minutes if that’s a thing in Loki) and add > 0 condition (again if that’s a thing with loki), then use Reduce to count number of points - since you know how many points there should be (e.g. 10 minutes range query with 1 minute resolution / step), if there’s less than 10 points, you can alert (I’d go for e.g. 3 minute pending period with 1 minute evaluation).
It could look something like this
in PromQL (I’m not sure unfortunately if / how to do that in Loki).
To route the notifications you can create notification policies based on customer label or have your own service handling those in some custom way.
Thanks for your answer. For my use case it’s not enough because I don’t want to worry about manually incrementing the number of customers in the alert.
It would be perfect if I can get the count of distinct customer’s labels in the threshold reduction, but this feature isn’t available.
I ended up solving this problem by creating a CLI with typer that deploy a customer app and uses the grafana provisioned API to create the heartbeat alerts.
