• Luchtvochtigheid BINNEN: {{ printf "%.1f" $values.F0.Value }} %
• Temperatuur BINNEN: {{ printf "%.1f" $values.F1.Value }} °C
• Temperatuur BUITEN: {{ printf "%.1f" $values.F2.Value }} °C
• Barometer: {{ printf "%.0f" $values.F3.Value }} mbar
And this is how the output looks like:
Can I give the text a different color or even the values?
Extra question, when the “barometer” value in this example is equal or higher than 1000 mbar it gets printed like 1.022k mbar. How can I make it look like this: 1022 mbar.
@bertschel the color of the text isn’t configurable. You can submit a feature request to have the dev team consider it. We use github discussions for feature requests:
I tested this out and it worked for me so unfortunately I can’t say what might be different. I’m using Grafana 9.3.6
