I am trying to setup a prometheus endpoint which is available only by setting the parameters.
curl -G -s -k -H “Authorization: Bearer {{TOKEN}}” ‘https://myurl/endpoint’ --data-urlencode ‘match[]=up’
I can set the Authorization header but not the parameter.
Grafana version: 9.2.4
