Can Alloy ingress windows "Applications and Services Logs" from event viewer
I have been able to ingress Application, System, and Security logs. But looking to ingress some of the Windows custom logs that are stored under Applications and Services Logs" These are dedicated .evtx files separate from the standard windows logs, but use the same Event Log engine.
