We have a use case that requires getting logs from different and previously unknown IPs. AFAIK node_exporter runs as a service and Prometheus server needs to connect to it. This requires manual configuration for every IP. Is there any way to automate this?
Our current ideas are:
- An API on the server the new machines can request to. The API will add the new IPs to Prometheus.
- We can alter the images the new machines boot with. Maybe a script that connects the server with ssh and adds the IP?
Does Grafana or Prometheus supports this kind of use case?
