Hey there,
i have a question about data handling in Grafana.
Target: Calculate driven range between battery loadings.
I have 2 different Influx Datasources. A has data about loading the battery. B has data about the driven ranges.
I can show booth sources as “mixed Datasource” into a graph. So I get a bar for loading, 5 bars for driven ranges, the a loading bar again and so on.
What I want is, to get a sum of the ranges between the loadings.
Example:
battery loading
driven 4km
driven 2km
driven 8km
loading
driven 15km
driven 4km
loading
should shown as
loading
driven (sum) 14km
loading
driven (sum) 19km
loading
So is it possible to do that in Grafana ?
Thank for help
regards
Manuel
