- Grafana v13.0.1+security-01 (9bbe672d1)
- To register data in a SQL Server database from business forms.
- I click on a data link to select a code, and it assigns it to a variable. Then I use this variable in the form, fill in the fields, and save.
What happened?
- When I click on the data link, the variable updates correctly with the selected value.
- The variable filters values in a query, and the query values are used as the initial values for the business form field.
- The problem is that the data it retrieves is not the correct value returned by the query, and for this reason, the field displays a different value.
- The query works; it filters the value and displays it correctly. The field populated by that query should show the same value, but it shows a different one.
Welcome @oscarqrt
Remove the early return statement
The return; in Custom Code was preventing everything below it from executing.
Map Initial Fields correctly
| Form Field | Query Field |
| Codigo | A:CodTarea |
| Tarea | A:TareaDesc |
| Horas | A:TiempoReportado |
Make sure your query alias matches the prefix used (e.g. A or A_update)
Fix the Update Request
From The Builder mode Switch to Code mode and use:
sql
UPDATE your_table
SET
TareaDesc = '${payload.TareaDesc}',
TiempoReportado = ${payload.TiempoReportado}
WHERE CodTarea = ${payload.CodTarea}
Variable Filter
Make sure your Business Forms query uses the variable correctly:
sql
SELECT CodTarea, TareaDesc, TiempoReportado
FROM Tareas
WHERE CodTarea = ${selectedCode}
Form showing correct values after clicking data link
Thank you so much for reproducing the problem; your suggestion works perfectly.
I was listing all the dashboards with this issue to apply the recommended solution, but I was surprised by a Business Forms update.
[6.3.5] - 01/06/2026
Fixed
The issue where form values lagged behind the selected variable when updating the dashboard, even with data synchronization enabled, has been resolved.
This saved a lot of time. Thank you so much!
Thanks @oscarqrt for your feedback
