I’m trying to perform a bulk download of multiple dashboards from an open source version of Grafana, but cannot find a way to download all dashboards while preserving the current folder structure. I can see the “Share” open when accessing an individual dashboard from within a given folder, but is there a way to export all dashboards across all folders into a single JSON? Below is an example of what the current folder structure looks like, each of which contain two or three embedded dashboards each.
@yosiasz - The intent is to be able to re-create the same dashboards and folder structure on another machine with the same operating system/version of Grafana. I’m trying to retrieve all of the dashboards in a single file (if possible), so that I can import the file (e.g. JSON) in another Grafana environment without having to create all the dashboard panels one by one. Please let me know if this is possible, thanks again!
@yosiasz - I came across that documentation on MySQL back-up/restore, but I more so need to export the dashboards and preserving the folder structure to re-create the configuration on another machine with Grafana. The second option may be more sufficient, but is there a plugin/feature using the Grafana API to support the bulk dashboard exports? Thanks again for your help!
