flopp
1
9.4.1
Separate each Parameter in a variable
Selecting more than one parameters in a variable
- What happened?
I get all parameters as series name
Get only one parameter as series name
After I upgraded to 9.4.1 I get all parameters when I use $m in Alias field
:Hi @flopp,
Thanks for opening this post.
Can you please try to reproduce this same issue on https://play.grafana.org/ and then share the dashboard link so that we can view it?
Thanks
flopp
3
I can reproduce it on Play, but I cannot save the dashboard changes.
Hi
Thanks for the quick reply. Yes, guest users cannot save the dashboard on the play.
Well, it is not clear to me to understand the issue. So, let’s go a few steps back and try to understand it.
Please review the submission template and include more details:
- What Grafana version you were using before upgrading to 9.4.1?
- What is your datasource?
- What visualization panel you are using e.g. time-series, bar chart, histogram etc?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Required* Is it possible for you to upload a screencast or a Gif as to how to reproduce it in the most simple and easiest way possible?
flopp
5
I logged in but it didn’t help, cannot save dashboard.
I had 9.3.6 before updating to 9.4.1
InfluxDB 2.x, Timeseries, no errors.
@grant2 Can you plz check? Looks like InfluxDB but not sure if it is specific to influxdb or a general one.
grant2
7
I am not able to check because on the system where I have variables in use, we are still on 9.3. I will let you know once we update.
flopp
8
seems to be solved in 9.4.7, can anyone confirm that this is the fix.
I have tested with version 9.4.7 and the error is not possibly to reproduce.
Influxdb: Re-introduce backend migration feature toggle by itsmylife · Pull Request #64842 · grafana/grafana (github.com)
