Browser back needs to pressed twice
If you have created links and are navigating from dashboard to another dashboard you need to press browser back button twice to get back one step. This seems to be because orgId url query parameter is pushed to location bar after dashboard navigation. Could it be possible to push the orgId at same time when dashboard is loaded or then use replace instead which doesn’t create a new browser history entry?
This is fixed in master and should be included in the new release, v4.4.0 next week.
