Hi !
I try to do a simple binary operation with 2 postgresql requests, but it does not work:
There is no result , it display nothing
Does someone knows why this simple addition does not work ?
thx
Hi !
thx
What visualization is that you are using? Also what do you mean by 2 postgresql requests, I think that might be the issue 2 queries?
Gauge
I use stat panel, but same with other visualisations.
And yes, i mean 2 queries.
But it works with MySQL queries. I have 2 MySQL queries, and I can do some operations between them.
ex:
But, with Postgresql queries, no, why ?
very interesting! I think it is a bug! submit it as such
the other option is to do it all in one query window also you can try?
