Part 1 :
Attaching to grafana
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Starting Grafana” logger=server version=7.1.1 commit=3039f9c3bd branch=HEAD compiled=2020-07-24T10:08:01+0000
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.log.mode=console”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from Environment variable” logger=settings var=“GF_PATHS_DATA=/var/lib/grafana”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from Environment variable” logger=settings var=“GF_PATHS_LOGS=/var/log/grafana”
Environment variable” logger=settings var=“GF_PATHS_PLUGINS=/var/lib/grafana/plugins”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from Environment variable” logger=settings var=“GF_PATHS_PROVISIONING=/etc/grafana/provisioning”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from Environment variable” logger=settings var=“GF_SERVER_HTTP_ADDR=127.0.0.1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Config overridden from Environment variable” logger=settings var=“GF_SERVER_HTTP_PORT=3001”
var=“GF_SERVER_ROOT_URL=https://****************/monitoring”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“App mode production” logger=settings
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Starting DB migration” logger=migrator
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create migration_log table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create user table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add unique index user.login”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add unique index user.email”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index UQE_user_login - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index UQE_user_email - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Rename table user to user_v1 - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create user table v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_user_login - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_user_email - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“copy data_source v1 to v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Drop old table user_v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column help_flags1 to user table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update user table charset”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add last_seen_at column to user”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add missing user data”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add is_disabled column to user”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add index user.login/user.email”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create temp user table v1-7”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_temp_user_email - v1-7”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_temp_user_org_id - v1-7”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_temp_user_code - v1-7”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_temp_user_status - v1-7”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update temp_user table charset”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create star table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add unique index star.user_id_dashboard_id”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create org table v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_org_name - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create org_user table v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_org_user_org_id - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_org_user_org_id_user_id - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update org table charset”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update org_user table charset”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Migrate all Read Only Viewers to Viewers”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create dashboard table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add index dashboard.account_id”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add unique index dashboard_account_id_slug”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create dashboard_tag table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add unique index dashboard_tag.dasboard_id_term”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index UQE_dashboard_tag_dashboard_id_term - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Rename table dashboard to dashboard_v1 - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create dashboard v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_dashboard_org_id - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_dashboard_org_id_slug - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“copy dashboard v1 to v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop table dashboard_v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“alter dashboard.data to mediumtext v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column updated_by in dashboard - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column created_by in dashboard - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column gnetId in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add index for gnetId in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column plugin_id in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add index for plugin_id in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add index for dashboard_id in dashboard_tag”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update dashboard table charset”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update dashboard_tag table charset”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column folder_id in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column isFolder in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column has_acl in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column uid in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update uid column values in dashboard”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add unique index dashboard_org_id_uid”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Remove unique index org_id_slug”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update dashboard title length”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add unique index for dashboard_org_id_title_folder_id”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create dashboard_provisioning”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Rename table dashboard_provisioning to dashboard_provisioning_tmp_qwerty - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create dashboard_provisioning v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_dashboard_provisioning_dashboard_id - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_dashboard_provisioning_dashboard_id_name - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“copy dashboard_provisioning v1 to v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop dashboard_provisioning_tmp_qwerty”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add check_sum column”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add index for dashboard_title”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create data_source table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add index data_source.account_id”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add unique index data_source.account_id_name”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index IDX_data_source_account_id - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index UQE_data_source_account_id_name - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Rename table data_source to data_source_v1 - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create data_source table v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_data_source_org_id - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_data_source_org_id_name - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Drop old table data_source_v1 #2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add column with_credentials”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add secure json data column”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update data_source table charset”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update initial version to 1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add read_only data column”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Migrate logging ds to loki ds”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update json_data with nulls”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add uid column”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update uid value”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Add unique index datasource_org_id_uid”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create api_key table”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add index api_key.account_id”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add index api_key.key”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“add index api_key.account_id_name”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index IDX_api_key_account_id - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index UQE_api_key_key - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“drop index UQE_api_key_account_id_name - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Rename table api_key to api_key_v1 - v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create api_key table v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index IDX_api_key_org_id - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_api_key_key - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“create index UQE_api_key_org_id_name - v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“copy api_key v1 to v2”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Drop old table api_key_v1”
grafana | t=2020-11-06T10:07:45+0000 lvl=info msg=“Executing migration” logger=migrator id=“Update api_key table charset”
