I’m trying to find the best panel to show Top N of a metric.
So far I only get decent result with Table Panel, which is operative, but nothing fancy…
Is there a way to show TopN value in a PieChart Panel or Graph Panel?
what I’ve tried so far → Piechart
But in influxDB, the query is OK, it returns 3 values…
SELECT top(“max”,host_name,3) FROM(SELECT max(“value”) FROM “metric_memory_usage” WHERE time >= now() - 7d GROUP BY “host_name”)
time top host_name
1561612600000000000 1099724640 wocudevel
1561973768000000000 85970408 wocu-demos
1561973777000000000 85970504 bgp-re
With Graph Panel I get this:
But If i want to limit TOP N…
To be continued…
(will upload another image in next message)
