Best value for readiness probe timeout? (kubernetes)
Hello
what is the best value for readiness probe timeout?
1 second (default) => probe fails after deployment scale down & up (for backup)
5 seconds => seems OK
15 seconds => probe fails
I use grafana helm chart 7.2.5 with openshift 4.12
BR
Pascal
It depends, e. g. what pod is doing when it’s starting (dashboard, plugin, alert provisioning,… you should see that from pod logs and then you can estimate time just for start). I would configure initialDelaySeconds (e. g. 30sec, see estimation from previous step if you need exact value for your case) so there is a time for start and then 10sec period.
Hello
according to the grafana container logs, it takes 20 seconds for startup,
So I set readiness-probe-initial- delay= 30 seconds
=> it works ! thanks!!
(except 1 readiness probe failed from kubelet 1 hour after restart)
would you also suggest increase readiness-probe-timeout ? (as I did increase it from 1 to 5 seconds, and it did fix the problem also)
thanks again
Pascal
That depends on your case. If you have single pod, which is under heavy load then it makes sense to increase a timeout. But if you have (auto) scaled pods, which are just sitting and waiting for requests, then it doesn’t make sense - healtcheck response should be quick in this case.
