Basic Math failing to yield expected results
    Grafana 9.0.3 in Home Assistant with Influx DB
    Multiply the results of two queries
    Using a Regular Expression
  • What happened?
    The result is unexpected from the data 17.9 * 0.195 = 3.04
    An accurate result would be 3.49
    Query A:
    SELECT last(“value”) FROM “autogen”.“kWh” WHERE (“entity_id”::tag = ‘octopus_energy_electricity_20j0027278_1413218722007_previous_accumulative_consumption’) AND $timeFilter GROUP BY time(24h) fill(null)
Query B:
SELECT last(“value”) FROM “autogen”.“GBP/kWh” WHERE (“entity_id”::tag = ‘octopus_energy_electricity_20j0027278_1413218722007_previous_rate’) AND $timeFilter GROUP BY time(24h) fill(null)
Expression Operation: Math $A * $B
Write expression queries | Grafana documentation
