Bar Chart Data Source Cognite Data Fusion
Hello:
I am reading events from Cognite Data Fusion (CDF) data source, but I cannot change the names of the type columns, all queries have the type column, how can I rename the graphs?
please help
GRAFANA FORUM’S 3 BEST PRACTICES:
  1. Please post inside a subcategory
  2. For questions and advice, please try to use the template below
  3. If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
  • What happened?
