Backup alerts in Grafana 8.5.4
Hello all,
Does anybody know if there is a way to backup Grafana alert definitions and a way to restore them?
You can export dashboards but alerts, you need a degree quantum computing :smile:
Is this something you need to script your way around (REST API)?
Thanks!
For anyone else trying to solve this issue, I ended researching about the Grafana REST API and eventually stumbled into the Grafana Backup Tool. It works really well, you should check it too.
