7.5.4 -
I want to see metric namespace “Microsoft.DBforPostgreSQL/flexibleServers” in Azure monitor plugin in Grafana -
What happened?
The Azure monitor plugin did not list “Microsoft.DBforPostgreSQL/flexibleServers” under metric namespaces -
I want to see “Microsoft.DBforPostgreSQL/flexibleServers” metric namespace inside Azure Monitor plugin -
Selected resourcegroup and listed available metric namespaces in Azure monitor plugin -
No errors -
No, I did not follow any
Do you have an update on this by any chance? Facing the same issue currently.
Also i raised an issue on github.
fix should be merged by now
