Grafana v7.5.7 (91de51771c)
- What are you trying to achieve?
Monitor memory usage for azure scale sets via Azure Monitor datasource
- How are you trying to achieve it?
Via Available Memory Bytes (Preview)
metric
- What happened?
The available memory bytes option is available for short bursts and then it goes away and I get the error provided below.
Memory graph to display available memory
"metricDefinition": "Microsoft.Compute/virtualMachineScaleSets", "metricName": "Available Memory Bytes", "metricNamespace": "Microsoft.Compute/virtualMachineScaleSets", "resourceGroup": "*-runner", "resourceName": "*-vmss-runner", "timeGrain": "auto", "timeGrains": [
request failed, status: 400 Failed to find metric configuration for provider: Microsoft.Compute, resource Type: virtualMachineScaleSets, metric: Available Memory Bytes, Valid metrics: Percentage CPU,Network In,Network Out,Disk Read Bytes,Disk Write Bytes,Disk Read Operations/Sec,Disk Write Operations/Sec,CPU Credits Remaining,CPU Credits Consumed,Data Disk Read Bytes/sec,Data Disk Write Bytes/sec,Data Disk Read Operations/Sec,Data Disk Write Operations/Sec,Data Disk Queue Depth,Data Disk Bandwidth Consumed Percentage,Data Disk IOPS Co
Here is a screen shot of how is looks until I occasionally get the error above
