I am trying to setup Loki in the Distributed Mode ..Facing this following error level=info ts=2026-05-12T06:31:16.082257826Z caller=reporter.go:169 msg=“failed to CAS cluster seed key” err="operation error S3: PutObject, https response error StatusCode: 501, RequestID: bom-1:KSA0SzWEfKZoecc96zkt3HQh2u4uGLJuQnHlIdklmN_UoUlO7hyTHOB2n4PAEfLL, HostID: , api error NotImplemented: AWS chunked encoding not supported.
Installation Method: HELM
Chart : grafana-community/loki
version 13.6.2
For the Object Storage i am using OCI ( Oracle Bucket ) the values.yaml is attached below
deploymentMode: Distributed
distributor:
replicas: 2
ingester:
replicas: 2
zoneAwareReplication:
enabled: false
compactor:
replicas: 1
indexGateway:
replicas: 1
ruler:
enabled: false
querier:
replicas: 1
queryFrontend:
replicas: 1
queryScheduler:
replicas: 1
lokiCanary:
enabled: false
test:
enabled: false
loki:
auth_enabled: false
storage:
bucketNames:
chunks: loki-beta
ruler: loki-beta
type: s3
s3:
s3: null
endpoint:
region: ap-mumbai-1
secretAccessKey:
accessKeyId: < key>
signatureVersion: v4
disable_dualstack: true
s3ForcePathStyle: true
insecure: true
http_config: {}
schemaConfig:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
backend:
replicas: 0
read:
replicas: 0
write:
replicas: 0
singleBinary:
replicas: 0
Am I missing something ?
