Hi there,
Is there any way to avoid request to secure.gravatar.com?
I’ve been playing around with the different options within the config file but as far as I can see any integration with cloud services is disabled, but still I see that request showing every now and then.
Any inputs will be much appreciated,
Cheers,
j
Thanks Markus,
Well that’s the config I’m using.
$ sudo cat /etc/grafana/grafana.ini | grep gravatar
disable gravatar profile images
disable_gravatar = true
But when I browse to Configuration > Server Admin I can see a DNS request for “secure.gravatar.com”
And shortly thereafter an HTTP request towards that IP:
Any thoughts?
Cheers,
j
That’s interesting WIll investigate
