Automatically calculate tomorrows date
    I want to determine tomorrows date in the YYYY-MM-DD format when the dashboard loads, or the query runs, because the API requires a start and end time to determine the range of values to return. If I supply it with todays date (start) and tomorrows date (end) it will return all the data from today until midnight
    I can get todays date from ${__from:date:YYYY-MM-DD} and this is working as expected in the query, so all I need now is tomorrows date?
which visualization are you using?
you might have to go with apache echarts plugin to manipulate from date to get to date
