Auto Set Time Range based on data
Currently from what I have researched I have to manually set the Time Range
Screenshot%20from%202018-10-01%2009-33-05
and there is no feature to set it to auto (setting ‘auto’ or blank did not work, apply button gets disabled)
So that means I have to configure a time manually for every chart or dashboard, so if I set something generic like say 5years, if there is not enough data it will show blank spaces and not intelligently skip it
Screenshot%20from%202018-10-01%2009-31-33
So I am basically look for the time range to be auto set based on the data for each chart, or skip null values / empty spaces in the chart if there is no data (see above screenshot)
Any update on this?
I’m thnking of many usecases where this would come in handy!
