Any way to manipulate variable's value?
    Grafana 10.1.5 as a part of TIG via docker on linux
    want to place data with cpu tagged 1,2,3… on the chart with cpu data tagged like cpu1, cpu2, cpu3…
    looking for a way to modify $cpu variable’s value from cpu1, cpu2, cpu3… to 1,2,3 at query level, thus being able to place both data on the same chart
telegraf’s data for cpu sensor look like this:
cpu,cpu=cpu0,host=loaner time_active=202224.15999999992,time_guest=30250.35,time_guest_nice=0,time_idle=1527035.04,time_iowait=1352,time_irq=0,time_nice=169.28,time_softirq=6281.4,time_steal=0,time_system=40097.14,time_user=154324.34 1568760922000000000
cpu,cpu=cpu0,host=loaner usage_active=31.249999981810106,usage_guest=2.083333333080696,usage_guest_nice=0,usage_idle=68.7500000181899,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=4.166666666161392,usage_user=25.000000002273737 1568760922000000000
cpu,cpu=cpu1,host=loaner time_active=201890.02000000002,time_guest=30508.41,time_guest_nice=0,time_idle=264641.18,time_iowait=210.44,time_irq=0,time_nice=181.75,time_softirq=4537.88,time_steal=0,time_system=39480.7,time_user=157479.25 1568760922000000000
cpu,cpu=cpu1,host=loaner usage_active=12.500000010610771,usage_guest=2.0833333328280585,usage_guest_nice=0,usage_idle=87.49999998938922,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=2.0833333332070145,usage_steal=0,usage_system=4.166666665656117,usage_user=4.166666666414029 1568760922000000000
but linux_cpu sensor sends data with differently tagged cpu:
linux_cpu,cpu=0,host=go scaling_max_freq=4700000i,cpuinfo_min_freq=400000i,cpuinfo_max_freq=4700000i,throttle_count=0i,throttle_max_time=0i,throttle_total_time=0i,scaling_cur_freq=803157i,scaling_min_freq=400000i 1617621150000000000
linux_cpu,cpu=1,host=go throttle_total_time=0i,scaling_cur_freq=802939i,scaling_min_freq=400000i,scaling_max_freq=4700000i,cpuinfo_min_freq=400000i,cpuinfo_max_freq=4700000i,throttle_count=0i,throttle_max_time=0i 1617621150000000000
linux_cpu,cpu=10,host=go throttle_max_time=0i,throttle_total_time=0i,scaling_cur_freq=838343i,scaling_min_freq=400000i,scaling_max_freq=4700000i,cpuinfo_min_freq=400000i,cpuinfo_max_freq=4700000i,throttle_count=0i 1617621150000000000
linux_cpu,cpu=11,host=go cpuinfo_max_freq=4700000i,throttle_count=0i,throttle_max_time=0i,throttle_total_time=0i,scaling_cur_freq=800054i,scaling_min_freq=400000i,scaling_max_freq=4700000i,cpuinfo_min_freq=400000i 1617621150000000000
linux_cpu,cpu=2,host=go throttle_total_time=0i,scaling_cur_freq=800404i,scaling_min_freq=400000i,scaling_max_freq=4700000i,cpuinfo_min_freq=400000i,cpuinfo_max_freq=4700000i,throttle_count=0i,throttle_max_time=0i 1617621150000000000
    digged in graphana docs to no avail
EDIT: i renamed the tag value at telegraf’s level as a workaround:
[[processors.regex]]
  namepass = ["linux_cpu"]
  [[processors.regex.tags]]
    key = "cpu"
    pattern = "(\\d+)"
    replacement = "cpu${1}"
would still be nice to be able to do the reverse at query level in grafana as i mentioned
