Any sort of inheritance of color and value mapping possible?
I find myself copy/pasting json versions of color and value maps that I use on different panels and dashboards. Is there any way to apply a color or value mapping config to a group, whether it’s a all panels in a dashboard or all dashboards? Even scripting it from some cli tools would be ok.
Until this latest version, as far as I know, the color and value maps only works at the specific panel. I don’t have any information if the color and value maps can put into sort of panel groups or other dashboards.
The work around is to check the JSON of the panel then copy it to other similar panel in the dashboard JSON file.
Regards,
Fadjar
Thanks, that’s sort of what I figured.
Provisioning is another way of global value mapping configuration
