Any simple configuration to run Mimir in docker compose?
I just want to use Mimir as simple as possible, but couldn’t find any tutorial. Could any one please share any simple Mimir configuration file to run with minimal requirement.
I want to run Grafana and Mimir in a docker compose in one computer.
I will create a node_exporter using Grafana agent(single binary) in another computer and remote_write directly to Mimir instance.
Welcome
Take a look at the declarative docker compose approach in video in this link
Do you have any compose file yet?
Also this that you could scale back a bit
I spun it up and this is what it looks like
