I downloaded the latest nightly, I’m sure I’m doing something wrong. When I use CTRL and + I get the zoom window. Am I doing something work?
Thanks
Thanks
if your on mac you need to use CMD (and I use by + you mean mouse click)
Also you need to have the Editor role to be allowed to create annotations
Thru the documentation I found out to use ctrl and +. I used it before the upgrade to the nightly and it was working. Did you try with the latest releases? Can it be that there is a bug in the release?
Thanks
I login as administrator.
Thanks
I have found the issue, on the bars does not work.
Thanks
