Annotations not showing
Hello. For some reason my annotations are not showing when I try creating them. Has anyone else had this issue?
I am able to create an annotation, but when I press “Save” there is nothing that gets saved.
Here are my annotation settings:
Thanks to all of those who reply in advance.
I have the same problem. You can define it, but then it is gone.
By the way, the console is full of errors.
They have nothing to do with annotations but that makes me sad.
Dirk
