Annotation table clear
Grafana 13.0.1, running in Docker on CentOS Linux.
I have 65+ million rows in the annotation table (PostgreSQL backend). I want to automatically clean up old annotations using built-in retention settings to prevent DB bloat and speed up future upgrades.
I configured the following in grafana.ini:
[annotations]
cleanupjob_batchsize = 200000
[annotations.dashboard]
max_age = 60d
max_annotations_to_keep = 1000000
[annotations.api]
max_age = 60d
I also tried adding:
[unified_alerting.state_history]
enabled = true
backend = annotations
[unified_alerting.state_history.annotations]
max_age = 60d
And restarted Grafana.
What happened?
  • No errors in logs.
  • Only this line appears:
    logger=annotation.app level=info msg="Starting annotation cleanup loop" interval=24h0m0s retention=2160h0m0s
  • The row count in the annotation table does not decrease even after 24+ hours.
  • No other logs related to legacy annotation cleanup (no level=error, no success messages).
Grafana should automatically delete annotations older than 60 days or keep only the newest 1M per type, especially since most of our annotations come from Unified Alerting (alert_id IS NOT NULL).
See above — full [annotations] and [unified_alerting] sections.
No errors. Only the annotation.app log line (which seems unrelated to the main annotation table).
Hey,
We’ve had similar problem but in our case setting
    unified_alerting.state_history.annotations:
      max_age: 14d
worked. We’ve also truncated the table with annotations. 60 days might be quite large history, can you double-check if there are no annotations that are older than 60 days?
