Hey all,
Been following this sample plugin tutorial and I’m wondering if
writing it in the latest ES6 syntax so I need Babel to transpile that to ES5 JavaScript
is required? Or can I just write in common js without babel, etc?
Thanks!
Hey all,
Thanks!
Yes you can of course write it in ES5 as that is what babel transpiles to. I used to have a ES5 example somewhere but cannot find it.
Perhaps you’d be able to help me reconstruct a base for a few of the files? Just trying to interpret the files in other plugins…
Given all the files are at the same files system level,
./module.js
./status.js
./module.html
module.js should be more or less this?
angular.module('status',[])
status.js should be in this format?
.controller('StatusCtrl', ['$scope', function ($scope) {
$scope.name = 'Superhero';
module.html
<div>
<h3>Status Control</h3>
{{name}}
</div>
Thanks!
Miles
Edit : Just found this here for creating directives for future reference :
@torkel Any thoughts?
Just look at the how the ES6 plugins transpile into ES5:
Ah thanks for confirming! I kept moving the code over from the Clock panel until I understood what was going on. I ended up almost exactly the same as you’ve posted.
I guess I was looking for a way to do this without putting everything through Systemjs, but we made up now and everything appears to be working – thanks!
'use strict';
System.register(['./status'], function (_export, _context) {
var StatusCtrl;
return {
setters: [function (_status) {
StatusCtrl = _status.StatusCtrl;
execute: function () {
_export('PanelCtrl', StatusCtrl);
