I have installed grafana and InfluxDB on the raspberry, connected with DynDNS.org and everything works perfectly. After creating the dashboard and trying to export the link to test the operation, the system always asks me to login to grafana.
How to do?
Hi @webtony7, welcome to the community!
It sounds like you’re trying to share a link to a dashboard. It’s expected behavior to ask someone with the link to login unless you’ve configured anonymous access. Make sure you read about the security implications of enabling it before you decide to try. For those reasons, it’s not available on Grafana Cloud.
You can publish a snapshot of the dashboard, which will allow anyone with the link to view it without logging in.
