I’m trying to align the end of the bar charts in a table.
However as you can see in the screenshot, this does not happen if numbers have a different amount of decimals.
Is there anything I can do to fix this?
Welcome
What if you used no bar at all then there wont be anything to align
I think by design bar charts are supposed to not be aligned otherwise why would you need them at all?
Sorry my question has been imprecise.
I mean, the alignment between the end of the bars, the gray area.
