Alias Grafana 7 how to?
In grafana 7 is there a way to create an alias for a random walk query? I cannot seem to find it after looking for quite some time. I am trying to follow a tutorial on flow charting and this is hanging me up a bit. (1st image is from flowcharting documentation, and the 2nd is from my grafana instance.)
Another issue… Looks like when you add multiple queries they are part of the same series? Is this expected behavior?
same here - interested to know if there is a solution/workaround
Its under The menu Transform and its called rename now.
Update:
What you are looking for is this maybe:
Use the test db data source. There you have alias and all the random walk series.
