Hi Guys,
I have a graph based on select with two fields, total resources and allocated resources.
I would like to create an alert when the allocated resources were equal to the total resources.
Is possible?
Hi Guys,
Is possible?
If you can write a metrics query that subtracts the total from the allocated, then you can specify an alert on that result
Torkel,
if I understand, I need to write one metric for every field from de same metric.
Does it impact performance?
