I used to have a template variable that had the name of the data source table. The type was constant.
I used that in the query of the graphs. It worked fine. All graphs have been drawn and displayed as expected.
SELECT mean("vcc") FROM /^$source$/ WHERE $timeFilter GROUP BY time($__interval) fill(null)
But when I set an alarm no condition was ever met.
Then I replaced the variable in the query by its value. Then, but only then, the alarms reacted and fired.
SELECT mean("vcc") FROM "n-s-006" WHERE $timeFilter GROUP BY time($__interval) fill(null)
I assume that the alarms do not resolve the template variables on checking the set condition in alarm config. I think this is a flaw. Is there a possibility to fix that?
Thank you,
Alex
