I’m using Grafana with InfluxDB 2.0 on MacOS. Both on localhost
I’m trying a simple query to filter multiple value by creating a variable, and using the variable to filter the query:
from(bucket: "bucket_name")
|> filter(fn: (r) => r["_measurement"] == "process_time")
|> filter(fn: (r) => contains(value: r["api"], set: {$api:json}))
|> filter(fn: (r) => r["_field"] == "latency")
|> group(columns: ["api"])
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: "mean")
I’m getting the following error:
invalid: runtime error @3 :6-3:60: filter: failed to evaluate filter function: keyword argument “set” should be of an array of type invalid, but got an array of type [string]
However, the query runs as expected when hardcoding the filter values:
|> filter(fn: (r) => r["api"] == "api_1" or r["api"] == "api_2")
|> yield(name: "mean")
jorrel
August 18, 2021, 2:55pm
#2
I am getting the same error, utilizing set, to establish a list of filters. What was noticed, however, is that the error also occurs within Influx. So I do not think that it is a Grafana issue.
I confirm you this problem is also possible in grafana.
I have exactly the same issue.
I have a variable called “family” and with this simple query, I have the same message.
from(bucket: “connected_pressure_raw_data”)
|> range(start: -2d)
|> filter(fn: (r) => r["_measurement"] == “monitoring”
and r._field == “Version”
and r.company == “X”
and contains(value: r[“family”], set: ${family:json}))
And I have the last grafana version.
Does someone have an idea about what’s the problem ?
Did this ever get sorted Ive just hit the same issue
I have some panels on the same dashboard where it works in some cases then what I add to another metric I get the error
I had a similar problem, and I solved it by changing the filtering order. A bit stupid of me
This was returning me an invalid type because the service tag was not available everywhere
from(bucket: "traefik")
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) => contains(value: r.service, set: ${service:json}))
|> filter(fn: (r) => r._measurement == "traefik.service.requests.total")
|> filter(fn: (r) => r.method == "POST" or r.method == "GET")
So by filtering first the measurement, it’s working
Hope this can help you
defic
March 9, 2022, 9:22am
#6
This is probably because not all records have that field. If you use contains, you need to first check that the field exists
|> filter(fn: (r) => exists r.test and contains(value: r.test, set: ${test:json}) )
I was replacing these regex filters with contains
and was faced this issue.
|> filter(fn: (r) => r["test"] =~ /^${test:regex}$/)
