Hi @all,
I have the following structure of metrics:
folder1.size_in_bytes
folder1.status
folder2.size_in_bytes
folder2.status
Now I want to sum all metrics “size_in bytes” where the metric “status” has the value 1.
Is that possible?
What I have to do?
BR
Are you using Graphite as data source?
Marcus
yes, I am using graphite.
BR
Jan
With your current setup of metrics naming you can’t do filtering. I would suggest you to change naming schema so that the status are part of the naming schema for size_in_bytes, i.e.
folder1.status.1.size_in_bytes
folder2.status.1.size_in_bytes
Marcus
