After upgrade to grafana 10.4.0 labels changed to series
I’m using elasticsearch datasource to create dashboard. Yesterday with Grafana 10.0.0 in alerts when I pressed “preview” I had in “Expression” and “Treshold” labels from main chart. Now in Grafana 10.4.0 I see only “Series1, Series2, Series3”.
Query to elaticsearch is simple, just added “group by Company”. In Grafana 10.0.0 that Company name was in “Expression” and “Treshold”. I could refer to as a Labels.
How to fix this in 10.4.0?
I think I’m having the same problem and haven’t found a solution yet.
We have the same issue as well. Is there a workaround available or planned bug fix?
You should upgrade to 10.4.1.
Hi Jangaraj and Delinea support,
thank you for the feedback.
We can confirm it works again after updating to version 10.4.1.
Regards,
Frane
