Advisor stopped working today after upgrade to Grafana 12.4.0
After upgrade to 12.4.0 I am getting errors for each of the Advisor checks like below.
<30>1 2026-02-24T19:42:05.09778-05:00 raspberry05 grafana 196904 - - t=2026-02-24T19:42:05.097484854-05:00 level=error caller=logger.go:234 time=2026-02-24T19:42:05.097466114-05:00 msg=“Error processing check” app=advisor.app check=instance error=“checks.advisor.grafana.app \“check-t8t2q\” not found”
The Advisor check never completes and I am seeing this error when starting and deleting the Advisor run.
<30>1 2026-02-24T19:42:12.273126-05:00 raspberry05 grafana 196904 - - logger=resource-client-auth-interceptor t=2026-02-24T19:42:12.272724488-05:00 level=warn msg=“calling resource store as the service without id token or marking it as the service identity” subject=user:1 uid=user:df4ws1qfw1c74e
The Advisor had been working fine up until the upgrade.
Hello @scootertramp what os you are using?
i am try on my local host m/c , self hosted grafana version 12.3.1 and advisor work fine now.
now i will update the grafana version to 12.4.0 and advisor work fine
The o/s is Debian trixie 13 on a raspberry pi 5.
Advisor is working again after upgrade to Grafana 12.4.1.
Grafana v12.4.1 (46a02dc12a)
