Hey everyone, I’m new to Grafana and to the forums, so hello!
I’m currently learning more about Grafana and reviewing an observability stack that our team is working with. I’m curious how it compares with what others are deploying.
The current stack is a mix of Grafana and non-Grafana components:
- Grafana for visualization
- Prometheus for metrics
- OpenSearch for logs
- Tempo for traces
One thing I’m trying to better understand is the architectural tradeoff between this approach and going with a more Grafana-native stack using Mimir for metrics and Loki for logs.
I wasn’t involved in the original decision to use Prometheus + OpenSearch, so I don’t have all the context behind that choice. I’m not necessarily looking to change it, but I’d really like to hear from people who have operated similar stacks.
For those who have evaluated or used these combinations:
- What led you to Prometheus vs. Mimir for metrics?
- What led you to OpenSearch vs. Loki for logs?
- Are there operational, scalability, cost, or supportability considerations that pushed you one direction or the other?
- If you were designing the stack again today, would you make the same choices?
Mostly looking to learn from others’ real-world experience. Thanks!
I would prefer every component from Grafana - LGTM stack. It is one vendor, so all these components should be playing together very well. You will grown so you will need mature solution - you can easily get paid support for whole stack or move to SaaS (Grafana Cloud).
It is also modern vendor, so you can find support also for modern signals, e.g. profiles - Pyroscope.
But on other side reality can be different. You must be working with existing stack (e.g. Prometheus, OpenSearch). Or team has already deep knowledge of those non Grafana stack, so there is no point to start with something different if it will cost a time/money.
Hi @djcooper, welcome to the community .
Prometheus vs Mimir
Prometheus is simple to run. You outgrow it when you need long retention at scale, high availability (duplicate instances) or multi-tenancy.
Mimir scales horizontally and stores data in object storage, but is more to run than a single Prometheus.
You can start with Prometheus and add Mimir later. Prometheus or Alloy can remote_write into it, and PromQL stays the same.
OpenSearch vs Loki
Loki indexes only labels and keeps log data in object storage, so it’s usually cheaper at high volume. It works best when you filter by labels first, and it needs low-cardinality labels. Broad full-text searches over long time ranges are slower.
OpenSearch indexes full text, so ad-hoc search and aggregations are fast. It suits security, audit and analytics use cases, but costs more in storage, compute and cluster tuning.
For a new setup, the all Grafana stack (Mimir, Loki, Tempo) is a sensible default, since the components are designed to work together and come from one vendor. For an existing Prometheus + OpenSearch stack your team knows, I’d keep it, since Grafana can query both. Migrate a part only when there’s a concrete problem, such as Prometheus retention or log storage cost.
Some additional context. The person who deployed it is new to grafana. I do not believe it is a case of ‘what my team knows’ in a drawing they put the grafana backed versions as option and still have not answered as to why they chose promethus / open search. I am deployed a second environment all grafana-native and the one main concern I had was ‘self - serve support’ vs OEM support
