I try to use a variable that depends on other variable
So I have my first variable
projectName = label_values(sonarqube_bugs, name)
branchName = label_values({name="$projectName"}, branch)
When I select a projectName, branchName is working
If i select more than one projectName or “All” branchName is not working
So I tried to configure
projectName custom all value = .+
branchName = label_values({name=~"$projectName"}, branch)
But it gives me all branches of all projects for each project.
Is there a way to do that ? Or is there a way to configure a default branchName value if (and only if) projectName is All ?
Also, if I select multiple value, branchName is not working, prometheus does not seems to support “in” operator, if there anyway to do that ?
Best regards,
