Adjust x axis grouping on a graph (daily, weekly, monthly etc) in dash
Hey there,
been trying to work out whether this is possible. If I have raw stats that is coming in from a datasource that is aggregated by day and displayed in a graph, is it possible to create a button/dropdown attached to the panel that lets you change the x axis from daily to monthly/quarterly/annual etc, so that it redraws the graph with an adjusted x axis showing the new time period?
so e.g. if i select a years worth of data but select quarterly from a drop down it’ll split a years worth of data into quarterly figures? if i then changed to monthly it would update the figures to monthly.
any help is appreciated. seems like something it would be great to be able to do.
