Hello !
8.0.0-Beta1 on Windows 2016 -
Using the new build-in TimeSeries Panel native plugin to draw Active / Reactive / Apparent Power graphs. -
By using the build-in TimeSeries Panel native plugin. -
What happened?
For the Active power graph (P), I can select the “Megawatt (MW)” unit.
For the Reactive power graph (Q), I can’t select the “Megavolt-ampere reactive (MVAr)” unit because it’s not in the list. Only ‘var’ and ‘kVAr’ are in it.
For the Apparent power graph (S), I can’t select the “Megavolt-ampere (MVA)” unit because it’s not in the list. Only ‘VA’ and ‘kVA’ are in it. -
Could you please add these two units to the Energy drop list please ?
Is it possible to specify other units thant thoses which are in the default list ? -
Thank you !
Regards
