Adding Jaeger data source
I’m running Grafana in docker: docker run -d -p 3000:3000 grafana/grafana:latest
Have seen the following in latest, 7.1.5, 7.0.0, and master-ubuntu. To reproduce:
Add a data source -> choose Jaeger -> “Select”
Settings panel comes up, “Datasource added” modal immediately appears.
Fill in URL with anything -> “Save & Test”
Modal with response code doesn’t appear at all. “Datasource updated” modal does appear though. Configuration continues to appear on Configuration -> Data Sources, but it does not appear when adding a query.
Comparing this to behavior when saving a Graphite configuration, it seems when I click “Save & Test” there should be a POST request to /render, but this request does not happen with Jaeger for some reason.
I know this plugin is widely used, but I can’t think of anything locally that could be causing this behavior. Wondering if anyone is able to reproduce this or has any ideas what could be going on?
