Adding influxdb load balancer in grafana gives unauthorized error
I have configured two infuxdb server in nginx https configuration in order to have redundancy for influxdb for grafana dashboard and generated SSL certificates at both nginx and grafana linux servers. checking influx load balancer from grafana using “curl https://172.16.4.194:443” is the load balancer address" and getting error “SSL certificate problem: self-signed certificate”. also getting error as “Unauthorized error access reading influxdb” I believe defined certificate path in grafana.ini and grafana.yaml correclty. Please any one suggest to fix the error and to add influxdb load balancer as a data source in grafana without any error.
